Acme error 400: Timeout during connect
Hi, I need help to understand what’s wrong with my domain dashboard.cloud.depot.pathozoom.com. I’m using Traefik Helm chart with the tls-alpn-01 challenge. It’s not the first time when I do so and usually it works. But now I’m getting the following error:
“level”: “error”,
“msg”: “Unable to obtain ACME certificate for domains “dashboard.cloud.depot.pathozoom.com” detected thanks to rule “Host:dashboard.cloud.depot.pathozoom.com” : unable to generate a certificate for the domains [dashboard.cloud.depot.pathozoom.com]: acme: Error -> One or more domains had a problem:\n[dashboard.cloud.depot.pathozoom.com] acme: error: 400 :: urn:ietf:params:acme:error:connection :: Timeout during connect (likely firewall problem), url: \n”,
“time”: “2020-02-12T10:33:17Z”
I’m out of ideas what can be wrong. Would appreciate any help.
I can’t reproduce the same timeout against your domain (using the TLS-ALPN challenge) using either the staging or live ACME servers.
Is it still happening if you try right now?
Just retried. The same error message.
Weird.
Let’s Encrypt can definitely access your server on the TLS-ALPN when I try: https://acme-v02.api.letsencrypt.org/get/authz-v3/2777094172
When you are deploying Traefik, is it trying to issue certificates for many domains, or just this one? I wonder if it is triggering some kind of firewall/connection limit to your cluster.
It looks like something wrong with Traefik itself. Here’s the response from letsencrypt API in my case: https://acme-v02.api.letsencrypt.org/get/authz-v3/2778730126
