I have an API that is running in Minikube and I have set it up to be exposed on an https domain. After setting up the Ingress object and associated Cert-Manager/LetsEncrypt configs the certificate is appearing as not ready :
kubectl get certificate
NAME READY SECRET AGE
memdump-secret False memdump-secret 11m
The 403 authorization error :
kubectl logs -l app=cert-manager,app.kubernetes.io/component=controller -n ingress-nginx >> certmgr.txt
I0412 11:17:27.690407 1 ingress.go:99] cert-manager/challenges/http01/selfCheck/http01/ensureIngress "msg"="found one existing HTTP01 solver ingress" "dnsName"="vaultserver.xyz" "related_resource_kind"="Ingress" "related_resource_name"="cm-acme-http-solver-xxx" "related_resource_namespace"="default" "related_resource_version"="v1" "resource_kind"="Challenge" "resource_name"="memdump-secret-wjcn7-xxx-xxx" "resource_namespace"="default" "resource_version"="v1" "type"="HTTP-01"
E0412 11:17:27.721978 1 sync.go:190] cert-manager/challenges "msg"="propagation check failed" "error"="wrong status code '502', expected '200'" "dnsName"="vaultserver.xyz" "resource_kind"="Challenge" "resource_name"="memdump-secret-wjcn7-xxx-xxx" "resource_namespace"="default" "resource_version"="v1" "type"="HTTP-01"
I0412 11:17:37.682527 1 pod.go:59] cert-manager/challenges/http01/selfCheck/http01/ensurePod "msg"="found one existing HTTP01 solver pod" "dnsName"="vaultserver.xyz" "related_resource_kind"="Pod" "related_resource_name"="cm-acme-http-solver-xxx" "related_resource_namespace"="default" "related_resource_version"="v1" "resource_kind"="Challenge" "resource_name"="memdump-secret-wjcn7-xxx-xxx" "resource_namespace"="default" "resource_version"="v1" "type"="HTTP-01"
I0412 11:17:37.682708 1 service.go:43] cert-manager/challenges/http01/selfCheck/http01/ensureService "msg"="found one existing HTTP01 solver Service for challenge resource" "dnsName"="vaultserver.xyz" "related_resource_kind"="Service" "related_resource_name"="cm-acme-http-solver-2ccnn" "related_resource_namespace"="default" "related_resource_version"="v1" "resource_kind"="Challenge" "resource_name"="memdump-secret-wjcn7-xxx-xxx" "resource_namespace"="default" "resource_version"="v1" "type"="HTTP-01"
I0412 11:17:37.682830 1 ingress.go:99] cert-manager/challenges/http01/selfCheck/http01/ensureIngress "msg"="found one existing HTTP01 solver ingress" "dnsName"="vaultserver.xyz" "related_resource_kind"="Ingress" "related_resource_name"="cm-acme-http-solver-xxx" "related_resource_namespace"="default" "related_resource_version"="v1" "resource_kind"="Challenge" "resource_name"="memdump-secret-wjcn7-xxx-xxx" "resource_namespace"="default" "resource_version"="v1" "type"="HTTP-01"
E0412 11:17:48.843592 1 sync.go:379] cert-manager/challenges/acceptChallenge "msg"="error waiting for authorization" "error"="acme: authorization error for vaultserver.xyz: 403 urn:ietf:params:acme:error:unauthorized: 146.xxx.xxx.xxx: Invalid response from https://vaultserver.xyz/.well-known/acme-challenge/iiwVcwn0ZxIViugq_u-PeDFeMot1vlgGh0l74WlnZws: 502" "dnsName"="vaultserver.xyz" "resource_kind"="Challenge" "resource_name"="memdump-secret-wjcn7-xxx-xxx" "resource_namespace"="default" "resource_version"="v1" "type"="HTTP-01"
E0412 11:17:48.969335 1 controller.go:98] ingress 'default/cm-acme-http-solver-xxx' in work queue no longer exists
I0412 11:17:49.095940 1 conditions.go:192] Found status change for Certificate "memdump-secret" condition "Issuing": "True" -> "False"; setting lastTransitionTime to 2023-04-12 11:17:49.095929145 +0000 UTC m=+12844.737001850
I0412 11:17:49.116149 1 trigger_controller.go:179] cert-manager/certificates-trigger "msg"="Backing off from issuance due to previously failed issuance(s). Issuance will next be attempted at 2023-04-12 15:17:49.000001708 +0000 UTC m=+27244.641074395" "key"="default/memdump-secret"
I0412 11:17:49.151440 1 trigger_controller.go:179] cert-manager/certificates-trigger "msg"="Backing off from issuance due to previously failed issuance(s). Issuance will next be attempted at 2023-04-12 15:17:49.000002098 +0000 UTC m=+27244.641074785" "key"="default/memdump-secret"
This how my ClusterIssuer is setup :
apiVersion: cert-manager.io/v1
kind: ClusterIssuer
metadata:
spec:
acme:
server: https://acme-v02.api.letsencrypt.org/directory
email: myemail@gmail.com
privateKeySecretRef:
solvers:
- http01:
ingress:
class: nginx
podTemplate:
spec:
nodeSelector:
"kubernetes.io/os": linux
And the Ingress object :
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
namespace: default
annotations:
cert-manager.io/cluster-issuer: letsencrypt
kubernetes.io/ingress.class: "nginx"
spec:
tls:
- hosts:
- vaultserver.xyz
secretName: memdump-secret
rules:
- host: vaultserver.xyz
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 7799
I have done the following checks :
- Although not strictly necessary I have the domain entry mapped in /etc/hosts :
127.0.1.1 ubuntu-devops ubuntu-devops
127.0.0.1 localhost 192.xxx.xx.x jenkinserver.website vaultserver.xyz
- Curl the domain. This is what I am getting :curl -kv https://vaultserver.xyz
- Trying 192.xxx.xx.x:443...
- TCP_NODELAY set
- Connected to vaultserver.xyz (192.xxx.xx.x) port 443 (#0)
- ALPN, offering h2
- ALPN, offering http/1.1
- successfully set certificate verify locations:
- CAfile: /etc/ssl/certs/ca-certificates.crt CApath: /etc/ssl/certs
- TLSv1.3 (OUT), TLS handshake, Client hello (1):
- TLSv1.3 (IN), TLS handshake, Server hello (2):
- TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
- TLSv1.3 (IN), TLS handshake, Certificate (11):
- TLSv1.3 (IN), TLS handshake, CERT verify (15):
- TLSv1.3 (IN), TLS handshake, Finished (20):
- TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
- TLSv1.3 (OUT), TLS handshake, Finished (20):
- SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
- ALPN, server accepted to use h2
- Server certificate:
- subject: O=Acme Co; CN=Kubernetes Ingress Controller Fake Certificate
- start date: Apr 12 07:43:48 2023 GMT
- expire date: Apr 11 07:43:48 2024 GMT
- issuer: O=Acme Co; CN=Kubernetes Ingress Controller Fake Certificate
- SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
- Using HTTP2, server supports multi-use
- Connection state changed (HTTP/2 confirmed)
- Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
- Using Stream ID: 1 (easy handle 0x559c867218f0)
GET / HTTP/2 Host: vaultserver.xyz ...
- TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
- old SSL session ID is stale, removing
- Connection state changed (MAX_CONCURRENT_STREAMS == 128)! < HTTP/2 502 ...
502 Bad Gateway ...
3.Dig my domain - and the correct IP is being returned :
dig vaultserver.xyz
; <<>> DiG 9.16.1-Ubuntu <<>> vaultserver.xyz
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 25711
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 65494
;; QUESTION SECTION:
;vaultserver.xyz. IN A
;; ANSWER SECTION:
vaultserver.xyz. 0 IN A 192.xxx.xx.x
;; Query time: 0 msec
;; SERVER: 127.0.0.53#53(127.0.0.53)
;; WHEN: Wed Apr 12 11:25:04 UTC 2023
;; MSG SIZE rcvd: 60
All components are also up :
kubectl -n ingress-nginx get pods
NAME READY STATUS RESTARTS AGE
cert-manager-xxx 1/1 Running 2 (27m ago) 7d19h
cert-manager-cainjector-xxx 1/1 Running 1 7d19h
cert-manager-webhook-xxx 1/1 Running 2 7d19h
ingress-nginx-admission-create-xxx 0/1 Completed 0 17d
ingress-nginx-admission-patch-xxx 0/1 Completed 1 17d
ingress-nginx-controller-xxx 1/1 Running 2 (27m ago) 17d
What am I missing ?
