Hello,
I cannot renew Let's Encrypt certificates using BitrixVM on my VPS hosted by IHOR.
Affected VPS public IPv4: 45.133.247.10.
Renewal from the same VPS succeeds when the ACME connection goes through a proxy on another VPS, 45.89.66.220.
My hosting provider suspects that the source IP is blocked on your side, but has not provided diagnostic evidence.
Could you help determine whether this is source-IP filtering or a network connectivity issue?
Affected domain: tehnokeramica.ru
Failure time, including timezone: 2026-11-04 13:00:58 UTC+03:00 (Moscow)
Exact renewal error: Problem connecting to server (get for https://acme-v02.api.letsencrypt.org/directory; curl returned with 28
Direct curl output from the affected VPS:
curl -4 -v --noproxy '*' --connect-timeout 15 --max-time 30 https://acme-v02.api.letsencrypt.org/directory
* Trying 172.65.32.248:443...
* Connection timed out after 15000 milliseconds
* Closing connection 0
curl: (28) Connection timed out after 15000 milliseconds
Curl output from the working VPS:
* About to connect() to acme-v02.api.letsencrypt.org port 443 (#0)
* Trying 172.65.32.248...
* Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* SSL connection using TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
* Server certificate:
* subject: CN=acme-v02.api.letsencrypt.org
* start date: Sep 28 05:48:18 2026 GMT
* expire date: Dec 27 05:48:17 2026 GMT
* common name: acme-v02.api.letsencrypt.org
* issuer: CN=YE2,O=Let's Encrypt,C=US
> GET /directory HTTP/1.1
> User-Agent: curl/7.29.0
> Host: acme-v02.api.letsencrypt.org
> Accept: */*
< HTTP/1.1 200 OK
< Server: nginx
< Date: Thu, 05 Nov 2026 06:56:14 GMT
< Content-Type: application/json
< Content-Length: 961
< Connection: keep-alive
< Cache-Control: public, max-age=0, no-cache
< X-Frame-Options: DENY
< Strict-Transport-Security: max-age=604800
"meta": {
"caaIdentities": [
"letsencrypt.org"
"profiles": {
"classic": "https://letsencrypt.org/docs/profiles#classic",
"shortlived": "https://letsencrypt.org/docs/profiles#shortlived",
"tlsserver": "https://letsencrypt.org/docs/profiles#tlsserver"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.8-July-06-2026.pdf",
"renewalInfo": "https://acme-v02.api.letsencrypt.org/acme/renewal-info",
"revokeCert": "https://acme-v02.api.letsencrypt.org/acme/revoke-cert",
"tR1l3tBEgok": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417"
* Connection #0 to host acme-v02.api.letsencrypt.org left intact
