Unfortunately this is implemented on the side of our email provider and we don't have the ability to make changes. I agree that it would be a lot better if we they confirmed the intent before unsubscribing!
I recently added some additional text to the email to make it clearer that it won't confirm the unsubscribe action. This should be rolled out to the production emails in the next while. Hopefully that helps somewhat!
Yes. ~/certbot/venv/bin/certbot register --update-registration --email yourname+1@example.com should work. You might have to change the ~/certbot/venv/bin portion based on where/how you installed Certbot.
Hi guys I accidentally unsubscribed. I meant to click on different window which was in front of this email, Anyone please post how you manage to get expiry notifications working again with satisfaction. Thanks
I unsubscribed because I didnât want any more notifications those domains mentioned in the email.
I realize that I unsubscribed from notifications from all my domains.
Maybe you should clarify that in the text next to the link, that the link unsubscribes from notification from all domains, not only those in the current email.
If you unsubscribe from one expiration warning email it will unsubscribe that address from all future expiration warnings.
Presently this isn't possible. It's a non-trivial amount of work and the expiration warnings are a best effort service. I recommend that for large organizations in particular that you have monitoring in place above and beyond the expiration warnings for the certificates you rely on.
Apologies for the poor experience. Can you use the workaround described on the expiration email docs page?
However, you can change the email address on your account, which effectively re-subscribes you. Many common email services treat yourname+1@example.com the same as yourname@example.com. So if you update your email address to yourname+1@example.com, you can start getting expiry mail again. With Certbot, use:
Unfortunately we can't since the service we use for sending email is responsible for generating the link ID and manages the unsubscribes. They have implemented it as a one-click action.
One example that was created by a community member here (and is not affiliated with Let's Encrypt) is
It uses a slightly different approach than the Let's Encrypt expiration notices. The latter are based on a history of all certificates ever issued by Let's Encrypt, while the former are based on actively monitoring whatever is being used by a particular specified site. So for example if you issued a Let's Encrypt cert for example.com and example.net, and then you completely stopped using example.net and renewed the cert only for example.com,
the Let's Encrypt warnings would say that you had failed to renew your example.net cert, because the CA knows that you once had a particular cert configuration and you no longer do, while
the Let's Monitor warning would say that everything was fine, if you had only signed up to monitor example.com, because at least that site still has a valid cert.
This is really incredible, I did hit the unsubscribe link by mistake and here I am. Impossible to re-subscribe, but at least this will last for only 1 year, right? After 1 year I will get the notifications again? Btw, good job, Mandrill, best experience ever! Too bad itâs not possible to follow the url on mouseover, it would have made the process even smoother. Or is it possible?
Actually it would make sense if the unsubscribe link was not included, if anyone stops using their email for renewing certs, it will eventually stop receiving expiration notifications anyway.
I think it is possible to use mandrill and send notifications without unsubscribe links.
Now 2020, and the accidental unsubscribe issue is still possible.
I also hope that Let's Encrypt will someday provide an option to resubscribe. In the mean time, everyone's best option continues to be to set up some other kind of site monitoring, which can help detect many kinds of problems, including certificate expiration. An option created by a community member here is
and there are dozens of self-hosted and third-party monitoring options which include certificate expiry warnings.
Many of these are better than Let's Encrypt's own expiry notification in most production use cases, because unlike Let's Encrypt's expiry notices, they detect whether the certificate that is being used in production is going to expire. Let's Encrypt's expiry notices can frequently have both false positives and false negatives, because they never actually connect to users' sites to see what certificates are deployed there.
If your site's availability to users is important to you, please do look into other monitoring services. The effort is well worth it.
