ls -l /etc/nginx/conf.d/*.conf
ls: cannot access '/etc/nginx/conf.d/*.conf': No such file or directory
ls -l /etc/nginx/sites-enabled
total 4
-rw-r--r-- 1 root root 876 May 31 04:37 default
lrwxrwxrwx 1 root root 55 Sep 19 08:32 mwiki.taktylstudios.com.conf -> /etc/nginx/sites-available/mwiki.taktylstudios.com.conf
lrwxrwxrwx 1 root root 57 May 6 07:52 staging.taktylstudios.com.conf -> /etc/nginx/sites-available/staging.taktylstudios.com.conf
MikeMcQ
September 20, 2022, 2:48am
23
and contents of this:
/etc/nginx/sites-enabled/mwiki.taktylstudios.com.conf
listen 80;
server_name mwiki.taktylstudios.com www.mwiki.taktylstudios.com ;
MikeMcQ
September 20, 2022, 2:51am
25
and this
/etc/nginx/sites-enabled/default
server_name mwiki.taktylstudios.com;
proxy_pass http://127.0.0.1:5000;
proxy_set_header Host $host;
ssl_certificate /etc/letsencrypt/live/mwiki.taktylstudios.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/mwiki.taktylstudios.com/privkey.pem; # managed by Certbot
if ($host = mwiki.taktylstudios.com) {
} # managed by Certbot
listen 80 default_server;
MikeMcQ
September 20, 2022, 2:54am
27
that's a funny place to hide the https server block
Would you please add 3 backticks before and after that data. Will be much easier to read
my bad sir im kinda newbie in this work hahaha
MikeMcQ
September 20, 2022, 2:58am
29
OK, I understand what you have now. In your first post you said you didn't need the mwiki cert anymore. Do you want to try to re-create it? Or, do you just want to delete it so nginx can start again?
yes sir that's why I removed it manually. I want to delete so that nginx can start again.
MikeMcQ
September 20, 2022, 3:03am
31
Once we get nginx started, do you want to make the mwiki cert again?
nope sir only the staging.taktylstudios.com is needed, I only created the mwiki.taktylstudios.com for testing purposes.
MikeMcQ
September 20, 2022, 3:07am
33
OK, that makes it easy. Just delete these two files:
rm /etc/nginx/sites-enabled/default
rm /etc/nginx/sites-enabled/mwiki.taktylstudios.com.conf
Then, try this again
sudo nginx -t
sudo nginx -t
whoo i think nginx is running now thanks a lot for your help and time I really appreciate it!
MikeMcQ
September 20, 2022, 3:12am
35
Sure. You are welcome. But, you need to start nginx to get it running. That just checked the syntax. But, it will start now.
yes sir i used the code: systemctl restart nginx
thanks to you again sir! you saved my job hahahaha
MikeMcQ
September 20, 2022, 3:14am
37
Since you no longer use mwiki domain name, you should remove the A record from the DNS too
oops you're right sir.. removing it now on our hosting account thanks!
system
Closed
October 20, 2022, 3:16am
39
