A problem after power outage
My domain is: nil.fi
I ran this command: rebooted servers concerned after power outage
It produced this output: e.g Chrome says Your connection is not private, … NET::ERR_CERT_COMMON_NAME_INVALID
My web server is (include version):nginx/1.12.2
The operating system my web server runs on is (include version): centos 7.5.1804
Strangely a few other domains on the same setup are working fine (e.g. hn-dev.eu). And to clarify, nil.fi used to work before the outage just fine
The cert for nil.fi is good for 2 more months.
Please show the URL and error message you get.
https://nil.fi/
The error comes from the browser, can’t upload the image here but it is a generic chrome error screen of connection not being private.
You can use paste.bin or similar service.
https://nil.fi/, https://apps.nil.fi/ and https://www.nil.fi/ work for me. They’re all using correct certificates.
(https://apps.nil.fi/ just returns a test web page, though.)
I’d double check that you don’t have nil.fi on your computer’s (where your browser is) /etc/hosts file.
Or that you’re on a network with split-horizon DNS for that domain.
What’s IP does your computer show for:
ping nil.fi
Also, are you behind NAT? Because 212.146.21.21 appears to be residential. This could just be a lack of loopback/hairpin NAT.
(For me, they all have the IPv4 address 212.146.21.21, and no IPv6.)
Yep, the IP is ok.
And now it seems to workwith Vivaldi (not yesterday after the power break happened), so maybe it is just chrome cache issue after all :confused:
I’ll check it further and unless the problem shows it again I just apologize and thank you.
I have it in the hosts file for the internal IP of (front) nginx server, but as I said it worked there before the outage just fine. But my Vivaldi gets it now right, so possibly it is just some Chrome cache issue
