A few issues, NXdomain error, SSLcert file empty, failed auth procedure
Please show:
sudo netstat -pant | grep -E '80|443'
tcp6 0 0 :::80 :::* LISTEN 1332/apache2
It seems to NOT be listening on port 443
Please show the vhost file for rafflegiftcards.com
If you are not sure where the vhost file is… (neither am I).
Try finding it with:
sudo grep -Eri 'known|challenge|VirtualHost|ServerName|ServerAlias|SSLCertificateFile' /opt/bitnami/apache2
seems to be all the vhost have dummy info, im going to change them real quick.
Virtual Hosts
Required modules: mod_log_config
If you want to maintain multiple domains/hostnames on your
machine you can setup VirtualHost containers for them. Most configurations
use only name-based virtual hosts so the server doesn’t need to worry about
IP addresses. This is indicated by the asterisks in the directives below.
Please see the documentation at
URL:http://httpd.apache.org/docs/2.4/vhosts/
for further details before you try to setup virtual hosts.
You may use the command line option ‘-S’ to verify your virtual host
configuration.
VirtualHost example:
Almost any Apache directive may go into a VirtualHost container.
The first VirtualHost section is used for all requests that do not
match a ServerName or ServerAlias in any block.
<VirtualHost *:80>
ServerAdmin webmaster@dummy-host.example.com
DocumentRoot “/opt/bitnami/apache2/docs/dummy-host.example.com”
ServerName dummy-host.example.com
ServerAlias www.dummy-host.example.com
ErrorLog “logs/dummy-host.example.com-error_log”
CustomLog “logs/dummy-host.example.com-access_log” common
<VirtualHost *:80>
ServerAdmin webmaster@dummy-host2.example.com
DocumentRoot “/opt/bitnami/apache2/docs/dummy-host2.example.com”
ServerName dummy-host2.example.com
ErrorLog “logs/dummy-host2.example.com-error_log”
CustomLog “logs/dummy-host2.example.com-access_log” common
this prob a better view
/opt/bitnami/apache2/conf/extra/httpd-default.conf:# ServerName directive.
/opt/bitnami/apache2/conf/extra/httpd-multilang-errordoc.conf:# even on a per-VirtualHost basis. The default include files will display
/opt/bitnami/apache2/conf/extra/httpd-info.conf:# with the URL of http://servername/server-status
/opt/bitnami/apache2/conf/extra/httpd-info.conf:# http://servername/server-info (requires that mod_info.c be loaded).
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf:# machine you can setup VirtualHost containers for them. Most configurations
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf:# VirtualHost example:
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf:# Almost any Apache directive may go into a VirtualHost container.
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf:# The first VirtualHost section is used for all requests that do not
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf:# match a ServerName or ServerAlias in any block.
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf:<VirtualHost *:80>
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf: ServerName dummy-host.example.com
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf: ServerAlias www.dummy-host.example.com
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf: ServerName dummy-host2.example.com
/opt/bitnami/apache2/conf/extra/httpd-ssl.conf:
/opt/bitnami/apache2/conf/extra/httpd-ssl.conf:ServerName www.example.com:443
/opt/bitnami/apache2/conf/extra/httpd-ssl.conf:# Point SSLCertificateFile at a PEM encoded certificate. If
/opt/bitnami/apache2/conf/extra/httpd-ssl.conf:SSLCertificateFile “/opt/bitnami/apache2/conf/server.crt”
/opt/bitnami/apache2/conf/extra/httpd-ssl.conf:#SSLCertificateFile “/opt/bitnami/apache2/conf/server-dsa.crt”
/opt/bitnami/apache2/conf/extra/httpd-ssl.conf:#SSLCertificateFile “/opt/bitnami/apache2/conf/server-ecc.crt”
/opt/bitnami/apache2/conf/extra/httpd-ssl.conf:# the referenced file can be the same as SSLCertificateFile
/opt/bitnami/apache2/conf/bitnami/bitnami.conf: NameVirtualHost :80
/opt/bitnami/apache2/conf/bitnami/bitnami.conf: NameVirtualHost :443
/opt/bitnami/apache2/conf/bitnami/bitnami.conf:SSLCertificateFile “/opt/bitnami/apache2/conf/server.crt”
/opt/bitnami/apache2/conf/httpd.conf:# ports, instead of the default. See also the
/opt/bitnami/apache2/conf/httpd.conf:# definition. These values also provide defaults for
/opt/bitnami/apache2/conf/httpd.conf:# any containers you may define later in the file.
/opt/bitnami/apache2/conf/httpd.conf:# All of these directives may appear inside containers,
/opt/bitnami/apache2/conf/httpd.conf:# ServerName gives the name and port that the server uses to identify itself.
/opt/bitnami/apache2/conf/httpd.conf:ServerName localhost:80
/opt/bitnami/apache2/conf/httpd.conf:# If you do not specify an ErrorLog directive within a
/opt/bitnami/apache2/conf/httpd.conf:# logged here. If you do define an error logfile for a
/opt/bitnami/apache2/conf/httpd.conf: # If you do not define any access logfiles within a
/opt/bitnami/apache2/conf/httpd.conf: # define per- access logfiles, transactions will be
/opt/bitnami/apache2/conf/original/extra/httpd-default.conf:# ServerName directive.
/opt/bitnami/apache2/conf/original/extra/httpd-multilang-errordoc.conf:# even on a per-VirtualHost basis. The default include files will display
/opt/bitnami/apache2/conf/original/extra/httpd-info.conf:# with the URL of http://servername/server-status
/opt/bitnami/apache2/conf/original/extra/httpd-info.conf:# http://servername/server-info (requires that mod_info.c be loaded).
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf:# machine you can setup VirtualHost containers for them. Most configurations
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf:# VirtualHost example:
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf:# Almost any Apache directive may go into a VirtualHost container.
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf:# The first VirtualHost section is used for all requests that do not
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf:# match a ServerName or ServerAlias in any block.
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf:<VirtualHost :80>
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf: ServerName dummy-host.example.com
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf: ServerAlias www.dummy-host.example.com
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf: ServerName dummy-host2.example.com
/opt/bitnami/apache2/conf/original/extra/httpd-ssl.conf:
/opt/bitnami/apache2/conf/original/extra/httpd-ssl.conf:ServerName www.example.com:443
/opt/bitnami/apache2/conf/original/extra/httpd-ssl.conf:# Point SSLCertificateFile at a PEM encoded certificate. If
/opt/bitnami/apache2/conf/original/extra/httpd-ssl.conf:SSLCertificateFile “/opt/bitnami/apache2/conf/server.crt”
/opt/bitnami/apache2/conf/original/extra/httpd-ssl.conf:#SSLCertificateFile “/opt/bitnami/apache2/conf/server-dsa.crt”
/opt/bitnami/apache2/conf/original/extra/httpd-ssl.conf:#SSLCertificateFile “/opt/bitnami/apache2/conf/server-ecc.crt”
/opt/bitnami/apache2/conf/original/extra/httpd-ssl.conf:# the referenced file can be the same as SSLCertificateFile
/opt/bitnami/apache2/conf/original/httpd.conf:# ports, instead of the default. See also the
/opt/bitnami/apache2/conf/original/httpd.conf:# definition. These values also provide defaults for
/opt/bitnami/apache2/conf/original/httpd.conf:# any containers you may define later in the file.
/opt/bitnami/apache2/conf/original/httpd.conf:# All of these directives may appear inside containers,
/opt/bitnami/apache2/conf/original/httpd.conf:# ServerName gives the name and port that the server uses to identify itself.
/opt/bitnami/apache2/conf/original/httpd.conf:#ServerName www.example.com:80
/opt/bitnami/apache2/conf/original/httpd.conf:# If you do not specify an ErrorLog directive within a
/opt/bitnami/apache2/conf/original/httpd.conf:# logged here. If you do define an error logfile for a
/opt/bitnami/apache2/conf/original/httpd.conf: # If you do not define any access logfiles within a
/opt/bitnami/apache2/conf/original/httpd.conf: # define per- access logfiles, transactions will be
Binary file /opt/bitnami/apache2/modules/mod_pagespeed.so matches
Binary file /opt/bitnami/apache2/modules/mod_ssl.so matches
Binary file /opt/bitnami/apache2/modules/libphp7.so matches
Binary file /opt/bitnami/apache2/modules/mod_pagespeed_ap24.so matches
Binary file /opt/bitnami/apache2/modules/mod_log_config.so matches
Binary file /opt/bitnami/apache2/modules/mod_security2.so matches
/opt/bitnami/apache2/include/httpd.h: * The address 255.255.255.255, when used as a virtualhost address,
/opt/bitnami/apache2/include/httpd.h: /
The name given in “” /
Normal names for ServerAlias servers /
Wildcarded names for ServerAlias servers /
/opt/bitnami/apache2/include/http_config.h:#define NOT_IN_VIRTUALHOST 0x01 /*< Forbidden in <VirtualHost> /
/opt/bitnami/apache2/include/http_config.h:/
Forbidden in <VirtualHost>/<Limit>/<Directory>/<Location>/<Files>/<If><Proxy>
/opt/bitnami/apache2/include/http_config.h:#define GLOBAL_ONLY (NOT_IN_VIRTUALHOST|NOT_IN_DIR_CONTEXT)
/opt/bitnami/apache2/include/http_vhost.h: * handle addresses in “” statement
/opt/bitnami/apache2/include/http_vhost.h: * @param hostname The hostname in the VirtualHost statement
/opt/bitnami/apache2/include/http_vhost.h: * handle NameVirtualHost directive
Binary file /opt/bitnami/apache2/bin/httpd.bin matches
Agreed; all those files are unused or unrelated.
There should be one with "rafflegiftcards.com" in it...
But since I don't know where Bitnami places its' vhost config files, I am unable to locate it.
I’ve found the 2 vhost file that Bitnami uses per there doc. one has this output:
App url moved to root
DocumentRoot “/opt/bitnami/apps/wordpress/htdocs”
#Alias /wordpress/ “/opt/bitnami/apps/wordpress/htdocs/”
#Alias /wordpress “/opt/bitnami/apps/wordpress/htdocs”
RewriteEngine On
RewriteCond “%{HTTP_HOST}” ^ec2-([0-9]{1,3})-([0-9]{1,3})-([0-9]{1,3})-([0-9]{1,3})….amazonaws.com(:[0-9])?$
RewriteRule “^/?(.*)” “%{REQUEST_SCHEME}://%1.%2.%3.%4%5/$1” [L,R=302,NE]
Include "/opt/bitnami/apps/wordpress/conf/httpd-app.conf
2nd output:
VirtualHost *:80>
ServerName wordpress.example.com
ServerAlias www.wordpress.example.com
Include "/opt/bitnami/apps/wordpress/conf/httpd-app.conf"
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile “/opt/bitnami/apps/wordpress/conf/certs/server.crt”
SSLCertificateKeyFile “/opt/bitnami/apps/wordpress/conf/certs/server.key”
The second one looks like it would do the job.
You just need to update the details to match the site and cert.
The cert is at:
I've changed it to look like the below, but apache2 still will not run nor can I run the cert again for the www mydomain
<VirtualHost *:80>
    ServerName rafflegiftcards.com
    ServerAlias www.rafflegiftcards.com
    DocumentRoot "/opt/bitnami/apps/wordpress/htdocs"
</VirtualHost>
<VirtualHost *:443>
    SSLEngine on
    SSLCertificateFile "/etc/letsencrypt/live/rafflegiftcards.com/fullchain.pem"
    SSLCertificateKeyFile "/etc/letsencrypt/live/rafflegiftcards.com/privkey.pem"
</VirtualHost>
Show output of:
apachectl configtest
it did no put anything but syntax OK
Please show:
sudo grep -Eri 'DocumentRoot|Servername' /opt/bitnami/apache2
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf: DocumentRoot “/opt/bitnami/apache2/docs/dummy-host.example.com”
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf: ServerName rafflegiftcards.com
/opt/bitnami/apache2/conf/extra/httpd-vhosts.conf: DocumentRoot “/opt/bitnami/apache2/docs/dummy-host2.example.com”
/opt/bitnami/apache2/conf/extra/httpd-ssl.conf:DocumentRoot “/opt/bitnami/apache2/htdocs”
/opt/bitnami/apache2/conf/bitnami/bitnami.conf: DocumentRoot “/opt/bitnami/apache2/htdocs”
/opt/bitnami/apache2/conf/httpd.conf:# DocumentRoot: The directory out of which you will serve your
/opt/bitnami/apache2/conf/httpd.conf:DocumentRoot “/opt/bitnami/apache2/htdocs”
/opt/bitnami/apache2/conf/httpd.conf: # access content that does not live under the DocumentRoot.
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf: DocumentRoot “/opt/bitnami/apache2/docs/dummy-host.example.com”
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf: ServerName rafflegiftcards.com
/opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf: DocumentRoot “/opt/bitnami/apache2/docs/dummy-host2.example.com”
/opt/bitnami/apache2/conf/original/extra/httpd-ssl.conf:DocumentRoot “/opt/bitnami/apache2/htdocs”
/opt/bitnami/apache2/conf/original/extra/httpd-ssl.conf:ServerName www.rafflegiftcards.com:443
/opt/bitnami/apache2/conf/original/httpd.conf:# DocumentRoot: The directory out of which you will serve your
/opt/bitnami/apache2/conf/original/httpd.conf:DocumentRoot “/opt/bitnami/apache2/htdocs”
/opt/bitnami/apache2/conf/original/httpd.conf: # access content that does not live under the DocumentRoot.
Binary file /opt/bitnami/apache2/modules/mod_vhost_alias.so matches
/opt/bitnami/apache2/include/httpd.h: * Default location of documents. Can be overridden by the DocumentRoot
Please show (individual posts):
sudo more /opt/bitnami/apache2/conf/extra/httpd-vhosts.conf
sudo more /opt/bitnami/apache2/conf/original/extra/httpd-vhosts.conf
sudo more /opt/bitnami/apache2/conf/original/extra/httpd-ssl.conf
Virtual Hosts
use only name-based virtual hosts so the server doesn't need to worry about
You may use the command line option '-S' to verify your virtual host
configuration.
<VirtualHost *:80>
DocumentRoot "/opt/bitnami/apache2/docs/dummy-host.example.com"
ErrorLog "logs/dummy-host.example.com-error_log"
CustomLog "logs/dummy-host.example.com-access_log" common
<VirtualHost *:80>
DocumentRoot "/opt/bitnami/apache2/docs/dummy-host2.example.com"
ErrorLog "logs/dummy-host2.example.com-error_log"
CustomLog "logs/dummy-host2.example.com-access_log" common
<VirtualHost *:80>
<VirtualHost *:80>
This is the Apache server configuration file providing SSL support.
It contains the configuration directives to instruct the server how to
serve pages over an https connection. For detailed information about these
directives see URL:http://httpd.apache.org/docs/2.4/mod/mod_ssl.html
Do NOT simply read the instructions in here without understanding
what they do. They’re here only as hints or reminders. If you are unsure
consult the online docs. You have been warned.
Required modules: mod_log_config, mod_setenvif, mod_ssl,
socache_shmcb_module (for default value of SSLSessionCache)
Pseudo Random Number Generator (PRNG):
Configure one or more sources to seed the PRNG of the SSL library.
The seed data should be of good random quality.
WARNING! On some platforms /dev/random blocks if not enough entropy
is available. This means you then cannot use the /dev/random device
because it would lead to very long connection times (as long as
it requires to make more entropy available). But usually those
platforms additionally provide a /dev/urandom device which doesn’t
block. So, if available, use this one instead. Read the mod_ssl User
Manual for more details.
#SSLRandomSeed startup file:/dev/random 512
#SSLRandomSeed startup file:/dev/urandom 512
#SSLRandomSeed connect file:/dev/random 512
#SSLRandomSeed connect file:/dev/urandom 512
When we also provide SSL we have to listen to the
standard HTTP port (see above) and to the HTTPS port
Listen 443
SSL Global Context
All SSL configuration in this context applies both to
the main server and all SSL-enabled virtual hosts.
SSL Cipher Suite:
List the ciphers that the client is permitted to negotiate,
and that httpd will negotiate as the client of a proxied server.
See the OpenSSL documentation for a complete list of ciphers, and
ensure these follow appropriate best practices for this deployment.
httpd 2.2.30, 2.4.13 and later force-disable aNULL, eNULL and EXP ciphers,
while OpenSSL disabled these by default in 0.9.8zf/1.0.0r/1.0.1m/1.0.2a.
SSLCipherSuite HIGH:MEDIUM:!MD5:!RC4:!3DES
SSLProxyCipherSuite HIGH:MEDIUM:!MD5:!RC4:!3DES
By the end of 2016, only TLSv1.2 ciphers should remain in use.
Older ciphers should be disallowed as soon as possible, while the
kRSA ciphers do not offer forward secrecy. These changes inhibit
older clients (such as IE6 SP2 or IE8 on Windows XP, or other legacy
non-browser tooling) from successfully connecting.
To restrict mod_ssl to use only TLSv1.2 ciphers, and disable
those protocols which do not support forward secrecy, replace
the SSLCipherSuite and SSLProxyCipherSuite directives above with
the following two directives, as soon as practical.
SSLCipherSuite HIGH:MEDIUM:!SSLv3:!kRSA
SSLProxyCipherSuite HIGH:MEDIUM:!SSLv3:!kRSA
User agents such as web browsers are not configured for the user’s
own preference of either security or performance, therefore this
must be the prerogative of the web server administrator who manages
cpu load versus confidentiality, so enforce the server’s cipher order.
SSLHonorCipherOrder on
SSL Protocol support:
List the protocol versions which clients are allowed to connect with.
Disable SSLv3 by default (cf. RFC 7525 3.1.1). TLSv1 (1.0) should be
disabled as quickly as practical. By the end of 2016, only the TLSv1.2
protocol or later should remain in use.
SSLProtocol all -SSLv3
SSLProxyProtocol all -SSLv3
Pass Phrase Dialog:
Configure the pass phrase gathering process.
The filtering dialog program (`builtin’ is an internal
terminal dialog) has to provide the pass phrase on stdout.
SSLPassPhraseDialog builtin
Inter-Process Session Cache:
Configure the SSL Session Cache: First the mechanism
to use and second the expiring timeout (in seconds).
#SSLSessionCache “dbm:/opt/bitnami/apache2/logs/ssl_scache”
SSLSessionCache “shmcb:/opt/bitnami/apache2/logs/ssl_scache(512000)”
SSLSessionCacheTimeout 300
OCSP Stapling (requires OpenSSL 0.9.8h or later)
This feature is disabled by default and requires at least
the two directives SSLUseStapling and SSLStaplingCache.
Refer to the documentation on OCSP Stapling in the SSL/TLS
How-To for more information.
Enable stapling for all SSL-enabled servers:
#SSLUseStapling On
Define a relatively small cache for OCSP Stapling using
the same mechanism that is used for the SSL session cache
above. If stapling is used with more than a few certificates,
the size may need to be increased. (AH01929 will be logged.)
#SSLStaplingCache “shmcb:/opt/bitnami/apache2/logs/ssl_stapling(32768)”
Seconds before valid OCSP responses are expired from the cache
#SSLStaplingStandardCacheTimeout 3600
Seconds before invalid OCSP responses are expired from the cache
#SSLStaplingErrorCacheTimeout 600
SSL Virtual Host Context
General setup for the virtual host
ServerAdmin you@example.com
ErrorLog “/opt/bitnami/apache2/logs/error_log”
TransferLog “/opt/bitnami/apache2/logs/access_log”
SSL Engine Switch:
Enable/Disable SSL for this virtual host.
SSLEngine on
Server Certificate:
the certificate is encrypted, then you will be prompted for a
pass phrase. Note that a kill -HUP will prompt again. Keep
in mind that if you have both an RSA and a DSA certificate you
can configure both in parallel (to also allow the use of DSA
ciphers, etc.)
Some ECC cipher suites (http://www.ietf.org/rfc/rfc4492.txt)
require an ECC certificate which can also be configured in
parallel.
Server Private Key:
If the key is not combined with the certificate, use this
directive to point at the key file. Keep in mind that if
you’ve both a RSA and a DSA private key you can configure
both in parallel (to also allow the use of DSA ciphers, etc.)
ECC keys, when in use, can also be configured in parallel
SSLCertificateKeyFile “/opt/bitnami/apache2/conf/server.key”
#SSLCertificateKeyFile “/opt/bitnami/apache2/conf/server-dsa.key”
#SSLCertificateKeyFile “/opt/bitnami/apache2/conf/server-ecc.key”
Server Certificate Chain:
Point SSLCertificateChainFile at a file containing the
concatenation of PEM encoded CA certificates which form the
certificate chain for the server certificate. Alternatively
when the CA certificates are directly appended to the server
certificate for convenience.
#SSLCertificateChainFile “/opt/bitnami/apache2/conf/server-ca.crt”
Certificate Authority (CA):
Set the CA certificate verification path where to find CA
certificates for client authentication or alternatively one
huge file containing all of them (file must be PEM encoded)
Note: Inside SSLCACertificatePath you need hash symlinks
to point to the certificate files. Use the provided
Makefile to update the hash symlinks after changes.
#SSLCACertificatePath “/opt/bitnami/apache2/conf/ssl.crt”
#SSLCACertificateFile “/opt/bitnami/apache2/conf/ssl.crt/ca-bundle.crt”
Certificate Revocation Lists (CRL):
Set the CA revocation path where to find CA CRLs for client
authentication or alternatively one huge file containing all
of them (file must be PEM encoded).
The CRL checking mode needs to be configured explicitly
through SSLCARevocationCheck (defaults to “none” otherwise).
Note: Inside SSLCARevocationPath you need hash symlinks
#SSLCARevocationPath “/opt/bitnami/apache2/conf/ssl.crl”
#SSLCARevocationFile “/opt/bitnami/apache2/conf/ssl.crl/ca-bundle.crl”
#SSLCARevocationCheck chain
Client Authentication (Type):
Client certificate verification type and depth. Types are
none, optional, require and optional_no_ca. Depth is a
number which specifies how deeply to verify the certificate
issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
#SSLVerifyDepth 10
TLS-SRP mutual authentication:
Enable TLS-SRP and set the path to the OpenSSL SRP verifier
file (containing login information for SRP user accounts).
Requires OpenSSL 1.0.1 or newer. See the mod_ssl FAQ for
detailed instructions on creating this file. Example:
“openssl srp -srpvfile /opt/bitnami/apache2/conf/passwd.srpv -add username”
#SSLSRPVerifierFile “/opt/bitnami/apache2/conf/passwd.srpv”
Access Control:
With SSLRequire you can do per-directory access control based
on arbitrary complex boolean expressions containing server
variable checks and other lookup directives. The syntax is a
mixture between C and Perl. See the mod_ssl documentation
for more details.
#SSLRequire ( %{SSL_CIPHER} !~ m/^(EXP|NULL)/ \
and %{SSL_CLIENT_S_DN_O} eq “Snake Oil, Ltd.” \
and %{SSL_CLIENT_S_DN_OU} in {“Staff”, “CA”, “Dev”} \
and %{TIME_WDAY} >= 1 and %{TIME_WDAY} <= 5 \
and %{TIME_HOUR} >= 8 and %{TIME_HOUR} <= 20 ) \
or %{REMOTE_ADDR} =~ m/^192.76.162.[0-9]+$/
SSL Engine Options:
Set various options for the SSL engine.
o FakeBasicAuth:
Translate the client X.509 into a Basic Authorisation. This means that
the standard Auth/DBMAuth methods can be used for access control. The
user name is the `one line’ version of the client’s X.509 certificate.
Note that no password is obtained from the user. Every entry in the user
file needs this password: `xxj31ZMTZzkVA’.
o ExportCertData:
This exports two additional environment variables: SSL_CLIENT_CERT and
SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
server (always existing) and the client (only existing when client
authentication is used). This can be used to import the certificates
into CGI scripts.
o StdEnvVars:
This exports the standard SSL/TLS related `SSL_*’ environment variables.
Per default this exportation is switched off for performance reasons,
because the extraction step is an expensive operation and is usually
useless for serving static content. So one usually enables the
exportation for CGI and SSI requests only.
o StrictRequire:
This denies access when “SSLRequireSSL” or “SSLRequire” applied even
under a “Satisfy any” situation, i.e. when it applies access is denied
and no other module can change it.
o OptRenegotiate:
This enables optimized SSL connection renegotiation handling when SSL
directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
<FilesMatch “.(cgi|shtml|phtml|php)$”>
SSLOptions +StdEnvVars
<Directory “/opt/bitnami/apache2/cgi-bin”>
SSL Protocol Adjustments:
The safe and default but still SSL/TLS standard compliant shutdown
approach is that mod_ssl sends the close notify alert but doesn’t wait for
the close notify alert from client. When you need a different shutdown
approach you can use one of the following variables:
o ssl-unclean-shutdown:
This forces an unclean shutdown when the connection is closed, i.e. no
SSL close notify alert is sent or allowed to be received. This violates
the SSL/TLS standard but is needed for some brain-dead browsers. Use
this when you receive I/O errors because of the standard approach where
mod_ssl sends the close notify alert.
o ssl-accurate-shutdown:
This forces an accurate shutdown when the connection is closed, i.e. a
SSL close notify alert is send and mod_ssl waits for the close notify
alert of the client. This is 100% SSL/TLS standard compliant, but in
practice often causes hanging connections with brain-dead browsers. Use
this only for browsers where you know that their SSL implementation
works correctly.
Notice: Most problems of broken clients are also related to the HTTP
keep-alive facility, so you usually additionally want to disable
keep-alive for those clients, too. Use variable “nokeepalive” for this.
Similarly, one has to force some clients to use HTTP/1.0 to workaround
their broken HTTP/1.1 implementation. Use variables “downgrade-1.0” and
“force-response-1.0” for this.
BrowserMatch “MSIE [2-5]”
nokeepalive ssl-unclean-shutdown
downgrade-1.0 force-response-1.0
Per-Server Logging:
The home of a custom SSL log file. Use this when you want a
compact non-error SSL logfile on a virtual host basis.
CustomLog “/opt/bitnami/apache2/logs/ssl_request_log”
“%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x “%r” %b”
Update file:
Remove the virtualhost sections:
<VirtualHost *:80>
<VirtualHost *:80>
