Trying to set up a Nextcloud box on a FreeBSD jail. I get the 404 not found error. Based on my Google-Fu, one of the common issues is that there is a AAAA record for the domain. I checked and there is no AAAA record.
Any ideas where to start?
My domain is:cloud.rangelmedianetwork.com
I ran this command: certbot certonly --webroot -w /usr/local/www/apache24/data/nextcloud -d cloud.rangelmedianetwork.com
My web server is (include version): Apache24
The operating system my web server runs on is (include version): FreeBSD jail in FreeNAS
My hosting provider, if applicable, is:N/A
The webroot should be the directory from which the root of the domain is served (so that if you put a file there eg test.txt it shows up at http://cloud.rangelmedianetwork.com/test.txt on the web).
It looks you have nextcloud installed at http://cloud.rangelmedianetwork.com/nextcloud - is /usr/local/www/apache24/data/nextcloud actually where nextcloud is installed? If so then the correct webroot path is probably /usr/local/www/apache24/data
Or it could be somewhere else if you used an alias - check your Apache configuration in that case, I guess.
It can, but the webserver has to be configured to use the same folder as its webroot too. I’m just guessing at how @oguruma’s webserver is already configured.
Or I guess you can do some tricks like mapping /.well-known/acme-challenge/ to a particular location so that the webserver doesn’t have to use that as its webroot for everything else - which I believe is how certbot’s apache and nginx plugins work behind the scenes - but it’s usually not necessary to go to that much trouble
You seem to have added a HTTP-to-HTTPS redirect since I last checked. That won’t work until you’ve fixed the issue that @schoen mentioned, and you’ll also need a certificate. While a self-signed cert would work for the validation process, it would probably be simpler to just remove the redirect, get a valid Let’s Encrypt cert, set up HTTPS in Apache, then put the redirect back in.
I removed the redirect. I’m not sure where the error in the configuration would be. I’ll admit I’ve only ever set up webservers from guides, and only on Linux.
Are you sure you removed the redirect? It seems to still redirect for me (except for the root page for some reason) - and apparently for the validation server too (note the https URL in the error message above)
It’s probably somewhere else indeed, as it’s affecting URLs outside of that directory. Could it be in your VirtualHost configuration? Or is there a file /usr/local/www/apache24/data/.htaccess?
Show the line in the config file that says: DocumentRoot /…
And there will be no doubt.
Otherwise show: grep -Eri 'alias|nextcloud|documentroot|challenge' /usr/local/www /etc/apache2
I don’t mean to sound confrontational.
It’s just that you say it’s there but the validation program can’t find the files certbot places in there.
Something is not working as you expect it to be.
I just don’t take anything for granted.
I don't believe we've seen any evidence of that yet. There was a 404 when the nextcloud subdirectory was used as the webroot, and an "Error getting validation data" when it redirected to broken HTTPS, but I don't think we've yet seen what happens when using /usr/local/www/apache24/datawithout redirecting - unless I've missed something?
