403 Unauthorized with uWSGI
#21
If you want to use PLAN B: update this to match:
If that fails (apache doesn’t like), use something more traditional:
replace that location block with:
<IfModule alias_module>
 Alias /.well-known/acme-challenge/ /etc/ACMEchallenge/
</IfModule>
[and ensure the alias module is loaded]
[look for something like:
LoadModule alias_module modules/mod_alias.so
in file /etc/apache2/apache2.conf]
#22
If apache can LIKE either of those methods, then.
Place a file in that new dedicated challenge folder:
mkdir /etc/ACMEchallenge/.well-known
mkdir /etc/ACMEchallenge/.well-known/acme-challenge
echo "testingX" > /etc/ACMEchallenge/.well-known/acme-challenge/1234567
and also (for sanity checking)
echo "testingY" > /etc/ACMEchallenge/123456789
Then we test for both new files with:
http://s.irminger.org/.well-known/acme-challenge/1234567
http://s.irminger.org/.well-known/acme-challenge/123456789
[one should be reachable]
#23
Apache liked the second option in Plan B, and the alias_module is loaded.
$ sudo apachectl -t -D DUMP_MODULES
lists - alias_module (shared)
I created the directories.
$ pwd
The echo commands as specified above came back with a permission denied.
$ echo “testingX” > /etc/ACMEchallenge/.well-known/acme-challenge/1234567
-bash: /etc/ACMEchallenge/.well-known/acme-challenge/1234567: Permission denied
So I referenced this-
and did this -
$ sudo bash -c ‘echo “hello” >/etc/ACMEchallenge/.well-known/acme-challenge/1234’
then
$ ls -a -l
total 16
drwxr-xr-x 2 root root 4096 Jan 24 10:39 .
drwxr-xr-x 3 root root 4096 Jan 24 10:32 …
-rw-r–r-- 1 root root 6 Jan 24 10:39 1234
and inaccessible online - 403 Forbidden
so I changed ownership
$ ls -a -l
total 16
drwxr-xr-x 2 www-data www-data 4096 Jan 24 10:39 .
drwxr-xr-x 3 www-data www-data 4096 Jan 24 10:32 …
-rw-r–r-- 1 www-data www-data 6 Jan 24 10:39 1234
restarted apache, still 403. http://s.irminger.org/.well-known/acme-challenge/1234
edit:
vhost
GNU nano 2.9.3 /etc/apache2/sites-available/s.irminger.org.conf
<VirtualHost *:80>
   ServerAdmin
    ServerName s.irminger.org
    ServerAlias www.s.irminger.org
DocumentRoot /var/www/s.irminger.org/
#<Location /.well-known/acme-challenge>
DocumentRoot /etc/ACMEchallenge
Options FollowSymLinks Includes
AllowOverride None
Require all granted
<Directory /var/www/s.irminger.org/searx>
AllowOverride All
Require all granted
    <Location />
        Options FollowSymLinks Indexes
        SetHandler uwsgi-handler
        uWSGISocket /run/uwsgi/app/searx/socket
    </Location>
also:
if I add
<Directory /etc/ACMEchallenge>
AllowOverride None
Require all granted
below the alias or in apache2.conf it shows the Searx page not found page.
#24
the port 80 virtual host was fine.
the port 443 virtual host was where the changes were to be made.
Please add three backticks on a separate line before and also after the “mangled” text.
Like:
test goes here
#25
I haven’t created anything 443-related since that would be generated through the certbot process. I should do a 443 virtual host? Which test do you mean?
> <VirtualHost *:80>
>        ServerAdmin
> #    DocumentRoot /etc/ACMEchallenge
> #       Options FollowSymLinks Includes
> #    AllowOverride None
> #    Require all granted
> #</Location>
> </IfModule>
>            AllowOverride All
>             Require all granted
>         </Directory>
>         <Location />
>         </Location>
> </VirtualHost>	> </VirtualHost>
#26
Sorry, that should have read TEXT (not TEST).
I may have gotten my wires crossed at some point (mixed this thread with another).
This section can remain in the port 80 vhost file (/etc/apache2/sites-available/s.irminger.org.conf):
[to help with the challenge requests]
    AllowOverride None
    Require all granted
</Location>
#27
Ok after reading this over we can move forward with testing “Plan B”.
Please reenable the “<Location /.well-known/acme-challenge>” and restart Apache.
Then lets place a file in that new dedicated challenge folder:
sudo bash -c 'echo "testingX" > /etc/ACMEchallenge/.well-known/acme-challenge/1234X'
and also (for sanity checking) in the challenge “root”:
sudo bash -c 'echo "testingY" > /etc/ACMEchallenge/1234Y'
Check that both files are there (and they are bigger than zero bytes)::
ls -l /etc/ACMEchallenge/.well-known/acme-challenge/1234X
ls -l /etc/ACMEchallenge/1234Y
If both OK, then we test access to them with:
http://s.irminger.org/.well-known/acme-challenge/1234X
http://s.irminger.org/.well-known/acme-challenge/1234Y
#28
I let this issue rest while I did other things.
I decided to spin up another VPS to try nginx. I was having the same exact problem trying to get certbot to run for www.s.irminger.org for searx on the nginx VPS.
I think this solution applies to the nginx server and would also resolve my original post about apache.
I referenced this post
and this question
the wsgi wasn’t allowing static pages.
this worked for nginx and I think something similar (for apache) would’ve resolved my issue before. I needed to let it serve static pages under /.well-known/acme-challenge
location ^~ /.well-known/acme-challenge/ {
root /var/www/searx/;
#29
Glad to hear this :slight_smile:
