My domain is: abc.com xyz.org ** these are not the actual names
My web server is (include version):apache
The operating system my web server runs on is (include version): ubuntu 18.04.4
My hosting provider, if applicable, is: single server on my home network.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using
Certbot): certbot-auto 1.5.0
sudo apachectl -S
notrealuser@Ubuntu11:/etc/apache2/sites-enabled$ sudo apachectl -S
[Thu Jul 02 13:16:05.108106 2020] [so:warn] [pid 3073] AH01574: module php7_module is already loaded, skipping
VirtualHost configuration:
*:80 is a NameVirtualHost
default server abc.com (/etc/apache2/sites-enabled/000-default-le-ssl-le-ssl.conf:2)
port 80 namevhost abc.com (/etc/apache2/sites-enabled/000-default-le-ssl-le-ssl.conf:2)
alias www.abc.com
port 80 namevhost xyz.org (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
alias www.xyz.org
port 80 namevhost abc.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:44)
alias www.abc.com
ServerRoot: “/etc/apache2”
Main DocumentRoot: “/var/www/html”
Main ErrorLog: “/var/log/apache2/error.log”
Mutex default: dir="/var/lock/apache2" mechanism=fcntl
PidFile: “/var/run/apache2/apache2.pid”
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=“www-data” id=33
Group: name=“www-data” id=33
ServerAdmin webmaster@localhost DocumentRoot /var/www/htmlErrorLog ${APACHE_LOG_DIR}/error.log
ServerName xyz.org
ServerAlias www.xyz.org
SSLCertificateFile /etc/letsencrypt/live/xyz.org/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/xyz.org/privkey.pem
RewriteEngine on
RewriteCond %{SERVER_NAME} =xyz.org [OR]
RewriteCond %{SERVER_NAME} =www.xyz.org
<VirtualHost *:80>
ServerName abc.com
ServerAlias www.abc.com
DocumentRoot /var/www/abc.com/html
RewriteEngine on
RewriteCond %{SERVER_NAME} =abc.com [OR]
RewriteCond %{SERVER_NAME} =www.abc.com
ServerAdmin webmaster@localhost ServerName abc.com ServerAlias www.abc.com DocumentRoot /var/www/abc.com/htmlInclude /etc/letsencrypt/options-ssl-apache.conf
SSLCertificateFile /etc/letsencrypt/live/abc.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/abc.com/privkey.pem
When I enter abc.com in my browser it works correctly.
When I enter xyz.org in my browser it redirects to abc.com and shows cert not valid because it’s xyz.org cert.
